Originally Posted by rob13572468
the starter relay is positive trigger... (can be found at immobilizar pin 12 also at the multifunction relay pack). if you need to have a negative trigger then you need to add a 30 A SPDT relay to convert it...
Thanks for the info Rob! In the end it didn't work out so easily so I had 2 change the setup a bit but in the end it's working!
Thanks!
