Old 06-30-2009, 07:42 AM   #15 (permalink)
kmt63
Elise Driver
kmt63's Avatar
Images: 2
apk919.that is a nice setup you have.is that ducted to the ic?the measurements that i need are with the scoop held to the car so the fit is good.take the tail of the caliper and insert it into the hole down to the cars mounting point.the scoop thickness is around .070 thick so when i take that off your measurement i have the stand off distance.so record the measurement to each hole.also if they would mount to those nut clips.then measure the thickness of that clip.so i can take that off too.thanks for your help on this.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
