Old 06-30-2009, 08:21 AM   #18 (permalink)
apk919
ΒÄŅNED
apk919's Avatar
Images: 20
Originally Posted by kmt63 View Post
apk919.that is a nice setup you have.is that ducted to the ic?the measurements that i need are with the scoop held to the car so the fit is good.take the tail of the caliper and insert it into the hole down to the cars mounting point.the scoop thickness is around .070 thick so when i take that off your measurement i have the stand off distance.so record the measurement to each hole.also if they would mount to those nut clips.then measure the thickness of that clip.so i can take that off too.thanks for your help on this.
Thanks, and yes; the ducting goes to the I/C... more here: 2007 Exige S Intercooler Air Flow Study
What if I measure the height of my standoff brackets? Is that effectively the measurement you're looking for? I'll measure the thickness of the clips as well.
