Old 06-30-2009, 10:18 AM   #91 (permalink)
apk919
ΒÄŅNED
apk919's Avatar
Images: 20
Originally Posted by xxxotic View Post
I will try it again tonight and see if I can get it.
Are there are only two clips on the left side, and then it fits into the grooves on the right hand side
I didnt see any clips on the right side.
I just seems like the outer box doesnt want to move that easily.
Maybe it was because it was 100 degrees inside my garage when I tried it this weekend and I was getting heat exhaustion!
You're right, there are no clips on the right side, but there are two "hinges", i.e. interlocking plastic pieces that allow to two halves to pivot from the right side. If both hinges are correctly positioned (and the filter is seated correctly), the box closes fairly easily. Otherwise, it seems like an impossibility...
