Originally Posted by kmt63
you would not use the bolts that would normally bolt to the clam split line.i think it would work.what is done with the plastic edging around the opening?is it cut where the clam hinges?i think the only thing you might have to do is loosen the scoops before you open the clam.when they are tight.they pinch into the plastic edging.
The plastic edging has been taken off. It looks fine without it. As long as the attachments do not link the bottom and top parts of the clam it would work. Is that the case?
