Originally Posted by slaughtr
The plastic edging has been taken off. It looks fine without it. As long as the attachments do not link the bottom and top parts of the clam it would work. Is that the case?
im thinking it would work.i think you may need to apply the plastic edging to the upper portion.above the split line.because on an elise.the scoop would need to rest on the edging at the top around to the back corner on the rear clam.i would need to modify the rear bracket so that it was a bit thicker.being that you are only using the inner bolt.the front bracket does not bolt to the clam.so that will be fine.
