Old 06-30-2009, 08:52 PM   #22 (permalink)
apk919
ΒÄŅNED
apk919's Avatar
Images: 20
Originally Posted by kmt63 View Post
alright sounds good.i will get those made up and out to you as soon as i get the measurements.
The measurements were taken from the surface of the clam (or the lower bracket) to the outer surface of the spirenut (which should correspond to the length of the required standoff). The spirenut material is 0.8mm in thickness, and the OEM fasteners come with a combination nylon/rubber washer used between the scoop and spirenut. The washer is a total of 2.5mm thick.
Pictures:
1) Mounting standoffs with measurements (14.9mm, 26.75mm, and 28.0mm)
2) Scoop in place (note tighter fit at bottom)
3) OEM hardware with nylon/rubber washer
