Old 07-01-2009, 07:41 AM   #22 (permalink)
kmt63
Elise Driver
kmt63's Avatar
Images: 2
alright.so the measurements you listed are what i need to cut?i thought the way you measured it that the washer was in the middle and you would have to take off from the stand off height to use the washer.i noticed when i fit the larger scoops to my no drill mounts that the holes will be in a slightly different spot.so i will provide a paper pattern for the holes on the elise.if you feel comfortable with your exige pattern then people could use that for the exige.
one last thing i will need is the width from the door near top and bottom out to the inside lip of the scoop.this is so i can make the grills for the exige.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
