Old 07-01-2009, 08:13 AM   #30 (permalink)
apk919
ΒÄŅNED
apk919's Avatar
Images: 20
Originally Posted by kmt63 View Post
alright.so the measurements you listed are what i need to cut?
Yes
i thought the way you measured it that the washer was in the middle and you would have to take off from the stand off height to use the washer.
I measured the height of my brackets, which already take into account the thickness of the washer... so it would be the same height as the standoffs.
i noticed when i fit the larger scoops to my no drill mounts that the holes will be in a slightly different spot.so i will provide a paper pattern for the holes on the elise.if you feel comfortable with your exige pattern then people could use that for the exige.
The pattern I have is an exact pattern of the OEM Exige scoop holes, which probably locate the bottom hole a bit too high... if your pattern works on your no drill mounts for the Elise with the larger scoops, I think it would work on the Exige too (since your mounts are intended to duplicate the OEM scoop mounting positions).
one last thing i will need is the width from the door near top and bottom out to the inside lip of the scoop.this is so i can make the grills for the exige.
I'll try and get to that today... I'm leaving SD tonight for a week; so it will be my last chance to take measurements from the car for a while.
i forgot to mention that i was going to use 1/2 inch hex bar to make the stand offs.so its close to 13 mil.is that to small for the exige holes?i can get some bigger bar if i need to.
Let me check on that too. How are you attaching the scoops/standoffs? Are you drilling and tapping the standoffs to be attached with screws at both ends, or are you drilling a larger diameter hole in the standoffs to allow longer screws to attach directly to the spirenuts on the clam?
EDIT: Oh yeah, just to pick a nit... when you say "13 mil", I think 13/1000ths of an inch... I usually abbreviate 13 millimeters as 13mm...
