Originally Posted by kmt63
the hex bar is 1/2 inch or 13mm.i made a pattern off a stock exige scoop and marked the wider scoop.i had to move the holes slightly from stock.the stand offs i made for the no drill mounts where tapped 5mm x .80.i put a stud in one end and the other is open for mounting the scoop.i think on the exige you could put a screw in from the back side to mount the stand off.correct?
Yes, correct... a fender washer or equivalent would be recommended since the holes in the clam are probably too large for a typical 5mm washer.
I took the following 3 photos at the top, middle, and bottom of the side scoop... I hope this helps with determining the grille dimensions. Don't mind the ghetto electrical tape on the front edge of the scoops...
My videos:
http://www.youtube.com/user/apk919
