Originally Posted by BatmobileS240
Would it be possible to just us longer bolts to secure the wider scoops into the stock Exige mounting holes?
Yes, but you'd still need something to act as a spacer between the scoop and the mounting points on the clam/bracket (i.e. a hollow "standoff").
Originally Posted by kmt63
what i am making for the exige is a threaded piece of hex bar.you screw this to the exige mounting points.then you attach the scoops to the threaded stand off.it will work the same as what apk has done.only in a lathe turned piece of aluminum.
+1
And it will look nicer too...
My videos:
http://www.youtube.com/user/apk919
