Old 07-03-2009, 09:32 AM   #3 (permalink)
dleogml
dleogml's Avatar
How can I swap ECU EU to USA vice versa?
Originally Posted by charliex View Post
they are identical in hardware, but not software, also the dealer cannot update it to a federal spec, doing so will disable the car.
Any possiblity?
changing wiring harness or changing tachometer??
Could you inform what's difference between EU spec and USA spec ECU?
I found sports ecu from ebay and want to buy.
Can I swap ecu???
2007 Elise / Laser Blue / Toybox48 wheel / Larini Sports Exhaust / Larini Sports Cat / Ohlins 2-way Suspension / liquidcaddy cupholder / Stock harness bar / 4 point seat belt / white double line stripe / 3.3kg Fire Extinguisher / Engine Room LED Light / Engine Hood grill modification / V-Shield(like Starshield)/C-One Final Drive(4.529->4.8)/ACT XTSS clutch Kit/Fidanza Aluminum Flywheel(7.5lbs)
dleogml is offline   Reply With Quote
