Originally Posted by ErictheBastard
I just ordered the last available set and THEN discovered this thread....
I'm wondering...Does it bottom out in the front or the rear? The minimum spring rate in the front is much softer than stock and the minimum spring rate in back is much stiffer than stock. I'm mainly getting these for ease of ride height adjustability, so I'm wondering if they can be used with the stock springs?
They are progressive rate springs (as are the OEM Track Pack springs), so they start out at a lower rate and then increase rate as they are compressed. I'd guess that you wouldn't have to worry about "bottoming out" with these springs. If the springs are the same diameter as the OEM springs, it may be possible to swap springs... I'm sure Shinoo could answer that question.
My videos:
http://www.youtube.com/user/apk919
