Old 07-05-2009, 07:50 PM   #50 (permalink)
kmt63
Elise Driver
kmt63's Avatar
Images: 2
Originally Posted by LordZ View Post
Was there any luck in making a better looking solution to fit these to the exige using the elise scoop brackets? Maybe there was and I missed the post?
Would love a set if I could leave them grill-less and still look semi decent inside the scoop.
today i made a template from the wider scoop to use on the exige.it is the lower mount like the no drill elise.it takes the stock exige mount out of the airstream.also will look better than a stock exige.this is the best pic i could find that sows what it will look like.the lower bracket has tape on it to protect the anodizing.they are black.so you can se that this will look much better than stock.also better airflow through the scoop.i sent thomas at really light stuff a set for his exige and stock scoops.waiting on him to install them and report on the fit.the other option is the stand offs for the exige factory mounts.im sending a set to andy in cali to try.they are a nice lathe turned piece that should look good too.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
