Old 07-08-2009, 07:03 PM   #2 (permalink)
TheViper
Alarmed & Dangerous
TheViper's Avatar
I know very little about the Esprit, but the symptoms you describe could be the Trinary switch not allowing operation due to low or high refrigerant pressures.
Originally Posted by Lotusrepair View Post
A/C clutch and radiator fans not working.
Can not get power to the a/c clutch. Tested the clutch and it works fine. The front fans also do not turn on with the panel switched to a/c. Checked the relays and they work. Checked the fuses and they are fine. Not sure where to look next? Following the wiring diagram but locating the wires and parts in the car is the problem.
Just purchased this unfinished project to add to the Lotus fleet.
