Old 07-09-2009, 08:00 AM   #6 (permalink)
Lotusrepair
Lotusrepair's Avatar
Yes, I did do the switch on the filter/dryer. The condenser is in front of the radiator. When I first looked at the switch I was not sure if it was a high or low pressure switch. The book referred to it as low cut off switch and I tested it in both shorted and open. Really don't want to put 3 lbs of r12 in the system to find I have to take it apart later. I own 2 recovery units, but you still loose some r12 in the process. I am trying to locate the fail failure monitor. Not sure where it is in the car. On the Elite all the fans come on when the a/c is working. I see the center fan only works with the a/c, but from what I saw on the drawing it looked like all 3 fans ran for the cooling.
It is hard to get to the otter switch to manually kick the fans on.
Originally Posted by Quicker View Post
when you say you shorted the switch - you did the pressure switch on top of the condenser? (with the little sight bubble).
the fans normally only come on at about 95 - unless you have the AC on (and working). without the AC the center one will never come on. you can test the fans seperately by running a wire from a good 12V+ and try to energize each fan one-by-one, then start working backwards....
Lotusrepair is offline   Reply With Quote
