Fixed........!!!!!!!!!
Pulled the radio out and went through the plug connections for the system. Made sure all the pins were fully set in the housings and tried the system. It worked. Put everything back together and the system still works. Charged the system and the results are good. Sight glass is fine. Temp is good. Pressures on the gauges are good.
Now on to the next item on the list.....
