Thread: Head R&R
Old 07-14-2009, 10:29 PM   #2 (permalink)
Harrybauls
Harrybauls's Avatar
Originally Posted by Maypo View Post
Okay, I'm removing the cylinder head to replace a broken valve (and whatever other damaged parts I find) and I find that the long bolt that attaches the accessory belt tensioner assembly is too long to be completely removed. The bolt runs into the frame.
Will I be able to remove the timing cover and this tensioner assembly simultaneously? Can someone who has performed this task give me some guidance on this?
You should be able to jack the engine up a enough to get enough clearance (after unfastening a 3 of 4 of engine mounts to get it free - leave the back engine mount in place). I had to have a go at this bolt (I took the engine out) after it sheared off at the race track due to being over torqued at the factory. Major PITA - I lost the head gasket from over heating and had to drill out the old bolt.
Harrybauls is offline   Reply With Quote
