Front clam damage too? Grrr, that's stinks
Don't sweat the car not starting. Given the world record speed install, it doesn't surprise me that it might need a little help. First check your fuses. Seems like the coil fuse will pop from time to time if you're jump starting or cranking for a long time.
You may need a different serial->usb converter. I'm by no means a computer guru, but I have found that those converters are not all created equal. Once you get her hooked up, upload that new firmware first and then the map I sent out and she should tick right over unless something just "ain't right". You should be able to identify if anything isn't right buy looking at your data controls on the lap top. Call me or Kris if you need anything. You know we're always happy to help
Best,
Phil
