Originally Posted by buzzy
So those max rpm's do look high, when my first ECU dump was done at the first service mine was showing similar and I picked the car up with 8 delivery miles on the clock.
That said, with the fastest 0-60 of 25sec and a throttle never over 80% it looks ok to me.
YMMV I'm no expert though...
I've only seen one ECU dump with a 0-60 that wasn't 25sec.
and never seen one that showed more than 80% throttle.
Just as a FYI.
Even mine, which was tracked, showed no time above 80% throttle... so consider 80% the same as 100%, in most cases.
