Originally Posted by paulhastings
Checking the inner toe link torque and it was spinning in the rear. Not easily actually the torque wrench did click but, not sure how accurate. Need to remove the wheel to get a wrench on the nut and try again. Should it be able to spin. Never check before as it should have had this done at the first dealer service.
Are you holding the nut in front of the lower A-arm attachment point with a second wrench while you're torqueing the bolt head from the rear? You can't tighten it properly otherwise...
My videos:
http://www.youtube.com/user/apk919
