I guess I should have mentioned my car is an '07 Exige with the track pack. Would this explain not having the protruding ridge?
There is - on the OEM toe-link bolt/ball joint. There is a slot in the frame that interfaces protruding "ridge" on the toe-link ball joint that prevents the ball joint from spinning in place. However, when you replace that with a toe-link brace, there is a normal bolt that goes in the hole and nothing to keep it from turning except the wrench you put on it to hole it in place.
I don't know where it is published and don't think that Lotus has updated the Service Manual, but there has been reliable inofrmation (a copy of a letter?) that the Service Manual is not correct and the torque value has been increased.
