Old 09-20-2009, 12:56 PM   #13 (permalink)
ChrisH
Mountain Road Nut
ChrisH's Avatar
Originally Posted by ads_green View Post
I've just been out to have a quick go with the engine mount inserts and failed on the first mount (lower rear).
There's nothing special here with this bolt? I suspect it's just me only having a relatively small wrench (9") so probably need something with a little more length. Just want to check first before I have another go with a longer wrench.
Ta
Which bolt is causing you trouble? Getting them off or on? On the rear mount, the front bolts for the bracket to the frame are hard to access. If I recall correctly (it has been awhile), I just had to use a box end wrench and use muscle to get them off.
