Old 09-23-2009, 12:48 AM   #43 (permalink)
ZJChaser
Blue Wheel Pimp
ZJChaser's Avatar
Originally Posted by Demonized View Post
The CharlieX tune is a "FI" tune becuase it was built from the ground up by Charlie for the FI application, where-as the PES tune is a modified NA (stock) tune.
I believe the difference there is actually that charlie uses the higher resolution map from the factory FI tunes where as the PES uses the map from the factory NA tune which is a lower resolution map....or something like that.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
