No way on stock ECU engine protection (except possible knock detection which is marginal at best - one sensor in the middle of the motor just isn't going to give me confidence). I don't know what engine protection you specifically refer to but atleast it is not implemented in stock ECU, just ask the numerous folks with blown motors running a stock ECU that hit the fuel slosh problem and/or oil slosh problem. Maybe you can "enable" these features with your reflashes but I'm not aware of a fuel pressure sensor in a stock setup even if the stock ECU could handle it?
There are a couple of stock oil pressure sensors, but again, they don't seem to offer any "protection". One is for VVT and the other appears to be more of an On/Off oil presssure switch no measured range.
I can understand that it might no be easy to turn your software into a good end user friendly interface and hence not worth the effort. I may not agree with you, but I can't understand your point. If I were to hazard a guess based on your customer base count, you probably have about $50,000 potential, sure if it takes 3-6 months to build a quality end user interface, then it might not be worth it -- pending what you "think" projected sales would be beyond current users base.
As far as not many people tracking their Lotus, I think you are WAY off on your estimate. Every event I've done (and these aren't LCS events), I see more and more and more Loti out on the track (many owners of which never post or even read this forum) -- people are catching on to Lotus being pretty fast while also being VERY easy on rotors, pads, tires, and fuel -- it's becoming a good track sustainable car (once one sorts out the engine reliability).
Anyway, I'm trying to encourage you (Charlie), not discourage. I think your user tunable efforts would be rewarded and I believe there is room to grow for both EFI and your product.
Rob
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
