1. Remove the upper and lower steering column covers (6 screws ). Removing the trip reset button connector is recommended.
2. Remove the instrument cluster cover (four spring clips, pull toward the steering wheel, do not pull on the instrument shroud, only on the sides).
3. Remove instrument cluster (4 screws).
4. Remove the two lower column cover mounting brackets (4 screws).
5. Gently remove the instrument cluster, disconnect connectors (2).
6. Two machine screws hold the Switch Pack module to a dash bracket. Don't drop them!
7. Gently pull out the Switch Pack module.
8. Test and Reassemble. Be careful with the instrument cluster connectors and cable routing.
Originally Posted by 6i9
Ugh, I hope its just a connection issue...I dont have time to work on the car until next weekend though...
Judging by that picture, the SPM is a PITA the replace? Are there any DIY instructions out there
