Originally Posted by turbophil
Just to be clear, you "vent" to atmosphere and you *can drain* back to the tank... If the orange cap vents sufficiently, then you're fine.... although, I wouldn't think the orange cap is a great vent by the looks of it. You need what I would basically call an unrestricted source to vent the gasses out (like a little filter). If you choose to drain the oil back to the pan rather than draining the catch can, then a small oil fitting will suffice, as there's not that much oil that needs to flow back to the pan..
Hope that helps,
Phil
The opening on the orange cap is quite big, so big that I need to put a round foam around. Otherwise I need to clean that area all the time.
