Old 11-01-2009, 07:33 PM   #3 (permalink)
Aedo
anglophile in exile
Aedo's Avatar
Images: 88
Good writeup!
Originally Posted by Spudboy View Post
No offense, but your approach sounds much more likely to cause damage to either the seal, the paint, or the lamp. Pushing a flat bladed screwdriver thru the small hole underneath is far simpler and eliminates the risks.
This method is easy, works, and you won't damage the bodywork or paint - you can get the rubber gasket/seal out easily and without taking the lens out. Once it is out the lens is easy to extract (particularly if the tab is broken )
Aedo is offline   Reply With Quote
