Originally Posted by mrluky
ive always been 'taught' that its better to downshift rather than breaking if you need to slow down for, say an off ramp.
also, look at this video. this guy is definatly letting go of his wheel then grabbing it again when its at the right location
http://ae86levin.free.fr/ueo_style-1.wmv
Downshifting to slow down is NOT better than braking. Despite it being "conventional wisdom," it is incorrect. Using "compression braking" (downshifting to slow down) is harder on your transmission parts, which are much more expensive to replace than brake pads.
In performance driving, downshifting to "compression brake" creates an uncontrolled deceleration which can upset the balance of the car. At high speeds, it's almost a sure way to spin the car.
In performance driving, you downshift ONLY so that you are in the correct gear to exit a turn. This way you keep the RPMs in the fatter part of the "power band."
That's just a quick synopsis of the topic. Do a search, and you'll find tons more.
Mike
