Originally Posted by Tyger
I think you will be doing yourself (and us) a favor by posting at least "Section Four" of the VIN, which is everything after the check digit, starting with the Model Year character. If you only include the last four digits, you will end up with different cars with the same last four, meaning that sorts using the last four will not be in chronological order after the first model year.
You might notice that a lot of your entries so far did not bother to include a build date (probably because they didn't know where (or care) to look for it, so I would be wary about using that field to sort on.
You should definitely ask for the full VIN when people enter data which will certainly help weed out spurious entries.
You know, though, that once you have that, you have the info to reconstruct the whole VIN with ease, right?
