Old 04-21-2004, 05:24 AM   #2 (permalink)
Arno
Nerd on wheels
Arno's Avatar
Originally posted by meat
Mintex 1166's on my Exige (Motorsport Brake Package). My rear rotors are the Fed Elise front rotors, I believe.
Unlikely unless you have a very bizarre Exige..
PCD is different between S1/Exige and S2/Fed, so rotors would not fit without machining the holes.
Also the S1 discs have little or no offset on the center 'hat', while the S2 and Federal ones do, so you'd also need to run S2 hub carriers and bearings...
Unless you meant to write *pads* and not rotors.. Then that's correct yes. The motorsport brake kit moves the stock front caliphers to the back (loses the handbrake) and puts bigger 4-pot caliphers on the front.
Bye, Arno.
Arno is offline   Reply With Quote
