Old 07-29-2005, 05:07 AM   #3 (permalink)
arobot
The hole the broken bolt threads into opens into the transmission (I could hear it suck in air as I removed it). I've marked up Stan's photo to show where the bolt is on the Elise. Note, however, that the transmission in Stan's photo does NOT have the actual bolt- I've marked where it is on the Elise.
Originally Posted by Stan
Notice that one of the pair of bolts holds a clutch hydraulic hose bracket. These MAY possibly be accessory type bolts...meaning that you might be able to leave your busted bolt in place without harm!!! In other words they may turn out to do nothing internal to the gearbox and simply be used to hold external items. I'll see if I can find out more...
Hope things work out for you here.
arobot is offline   Reply With Quote
