Over on an SVT Cobra website I have followed for the past 6 years, we had a ?petrochemical engineer go thru a multi page evaluation of oil. Mobil1 used to be a type iv lube, it is know a type III lube, but is still probably the best one out there. Here is my list I saved and rational for use
Group V: only needed for true racing
Redline
Motul
Group IV: Best for long drain intervals, towing, high temps, hard driving ie track days
Mobil1 Tri-synthetic (discontinued)
Amsoil
Mobil 1 Super-syn is closer to a group III lube but have multiple patents on a new molelecule that should keep it as a top tier product
Group III: cheap synoils. Buy only if the price is right as they are inferior to Group IV products which typically cost little more
Castrol Syntec
Valvoline Synpower
Pennzoil Synthetic
Havoline Synthetic, Exxon synthetic etc (some of the best priced synthetics around)
Group II: Highly refined mineral oils
Valvoline All climate
Pennzoil PZL turbo (Very good product except below 15 degrees)
Royal purple.
In conclusion, all these oils will do the job, choose your product based on need. Notice syn blends never mentioned, a 1% blend is still a blend. Ripoff
Group III's are fine but for typically no additional cost over Castrol, Valvoline, or Pennzoil you can use Mobil1 and have just about the best readily available oil around without kicking out $7-10 dollars per qt although these numbers may change due to increased fuel costs.
PS that article is MIA as this was created in 9/2002 and modified in 2003 when Mobil1 supersyn was released. And no, he doesn't work for Mobil or Exxon!!
Hope this helps!!
