Quick overview of Street Prepared rules for the Elise
The Elise runs in ASP in Street Prepared.
You can do all the stuff you could do above in the Stock Class rules and also some more:
1. Remove A/C.
2. You can add a wing (there is a max size). Spoilers. Splitters. Body trim can be removed.
3. Open up fenders for larger tires.
4. Fuel cell (must be +/-20% of original capacity and within 6" of stock location)
5. Change foot pedals.
6. Change seats, must be uphostered and padded.
7. Any steering wheel.
8. Any rim. You can change wheel studs or bolts.
9. Fully adjustable spring perches.
10. Change/remove bump stops.
11. Coil overs. Replace springs.
12. Use of shims or removal of metal to change alignments.
13. ANY swaybar (add rear)
14. Replace bushings, must be non-metallic.
15. Camber kits okay.
16. Any DOT brake line. Any single dual circuit master cylinder.
17. Air cooling ducts
18. Any battery, any location of battery.
19. Any ignition setting.
20. Any fuel injection.
21. Intake / exhaust port matching within 1" from opening.
22. Accusump. Oil coolers. Change oil pan.
23. Remove smog devices.
24. Alternate fuel lines up to 1/2" dia.
25. Headers. Manifolds.
26. Balance rotating parts, overbore to 0.0472". Cylinder heads milled up to 0.010". Change engine fan, shroud.
27. Alternate ECU.
28. Water injection.
29. Clutch. SHift linkage. LSD. Tranny cooler. Drive shafts. Short shift kits.
(THIS IS NOT A FULL LIST... just a general overview!!! READ THE RULEBOOK, do research)
Lexus GX-470 tow vehicle.
