We are currently running the Kumho Ecsta V710 in the folowing sizes:
front - 215/40-16 - 28 psi
rear - 245/45-17 - 28 psi
The fronts are a bear to mount. They need to be very warm to get them to seat.
The rears rub in the fender liners. We want to try spacers in the back to see if that solves the problem. Raising the pressures might also prevent the tires from deforming...
BWR adjustable front bar with adjustable end-link kit, set at full stiff.
Front Alignment: 0 toe, max negative camber = approx -.75 degrees
Rear Alignment: 1/8" toe-in each side, stock negative camber = approx. -1.75 degrees
Robert Puertas
