Old 10-17-2005, 04:16 PM   #90 (permalink)
Tyger
burning bright!
Tyger's Avatar
Originally Posted by Surferjer
bwahahahaha! Yes, it's amazing the little things you discover when you actually have to live with a vehicle. Here's one: quit using the horrible inset hex bolts, and switch to a metric standard head bolt. The bolt heads might be better in tight places, but they strip easily. I try to replace each one I take out with something sturdier.
If you try to use the hex key on a torx bolt (which is used for the hard top) it will not work very well and will tend to strip it. Are you sure you're using the right one, Jer?
