Increase the range of your remote
I recently replaced the factory alarm system in my Elise. One of the reasons was the ridiculous range of the stock remote. Even with a new battery, the range was about 1 foot from the driver’s window. Before removing the old cobra alarm system, I tried an experiment and found I could significantly increase the range with a simple modification. If you want to try it, here’s how:
Remove the blank panel from the passenger side dashboard area. Look towards the front and you will see the control unit for the Cobra sitting on a shelf. Using a screwdriver (or skinny fingers), pry the connector locking tabs inwards and lift up the connector. There should be enough wire to pull it out of the access hole.
Next, locate pin 13, which is the antenna wire. It is the black wire on the same end as the pink and green wire. Using a ‘splice & tap’ and a length of wire, splice into the black wire. After reading the next paragraph, put the wire back in the dash (keeping it as free from metal and as extended as possible), reconnect the connector and you’re done.
How long should the piece of wire be? I don’t know exactly, but 36” worked great in my test when I had it lying across the dash (range of about 30 feet!). There is an optimum length, but since I don’t know the frequency, or the characteristics of the factory “antenna”, it is trial and error. I would start with about 4 feet (or about the width of the dash) and cut it bit by bit until you get the best range. Any multi-strand wire will work…the factory wire is about 20 gauge. Also routing it along the windshield frame would probably give better reception. I didn’t try that or try to find the optimum wire length since I was replacing the whole system anyway.
In case you’re interested, I installed a Compustar with remote pager.
Tom
