Old 07-25-2005, 06:54 PM   #7 (permalink)
Dave
Mods are good for you
Dave's Avatar
Originally Posted by hpman
91 Octane is the max at the pump here in CA. That could be a problem???
Where did you tap into for the fuel input/mix with the nitros??
The 91 could be an issue with a wet system. You can buy octane boosters at the local auto store to supplement...usually runs about $6/bottle/tank. The booster from NOS seems to be the most popular. I tapped the fuel line where it runs just below the coolant overflow tank. The supplied T adapter/tap is the correct fuel line diameter. NOTE: The fuel line is hardened PVC. I split the line on my first attempt to insert the tap. I then used a blow dryer to warm then ends and soften them a bit...worked perfect.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline
