Old 10-02-2005, 07:57 PM   #1 (permalink)
ekological
ekological's Avatar
Images: 13
Elise HID conversion
Hi everyone,
The parts are finally in so I could now fill all orders. Included in the kit is everything you need to install a 100% reversible HID kit--there is no cutting of any wires. I've always hated stripping insulation off of factory wiring only to have to solder in a splice. The connection ends up being hard (from the solder) and just ugly with black electrical tape covering the joint which will get gooey with age.
Included in the kit:
- 2 H1 based HID bulbs
- 2 ballasts/ignitors (single unit vs. separate ballast and ignitor)
- 2 custom wire harnesses to provide power to the ballast
- 6 expanding rivets to secure ballast in place
- Installation instructions
Tools you'll need:
- The factory wheel bolt tool (for those who are using the factory splined lug bolts)
- a 17mm socket and breaker bar to remove the lug bolts
- a phillips screwdriver
- a 5mm allen wrench or socket
- a 1/4" drill bit and drill
- a pair of needle nose pliers
Pricing is as follows:
- XTec 35Watt kit (4500K or 6000K): $425
- XTec 50Watt Kit (have to check on color temps, but I believe it's the same): $465
- Rebased Philips bulbs and Philips XLD 145 slim ballast 4300K color temp 35Watt: $550
- Rebased Philips bulbs and Philips XLD 145 slim ballast 6000K color temp 35Watt: $650
Other configurations are available (e.g. HID high and low beam)...contact me for details. Do note that it's not good to cycle HIDs too frequently as this shortens life so the HID high beam option should be for those who cruise at night and need the extra visibility and not those who like to flash people to move out of the way
For the first 10 orders, I will pick up shipping. Otherwise, it's $15 shipping via UPS.
Thanks,
Chester
ekological is offline
