Thanks Mark. We can see that changing the front perch by 6 mm changes the front ride height 10 mm. And out back 8 mm at the spring leads to 10 mm at the chassis ride height checking point. This is due to the motion ratio through which the suspension articulates. They also suggest more negative camber out back than for the other Elise options. Some of that comes automatically through lowering. Does anyone know if they left the steering rack shim alone...and the free length of the springs if different than LSS.
