Originally Posted by charliex
yeah the top is really squeaky. its almost as if its saying, take me off, you know like bras do
If the connections are pins basically sliding sideways into
the flared rear section, as is the case with the gullwing, I
found that the fiberglass on the rear portion of the gullwing
panels would come in contact with the sidewall of the flared
(rear) sections. This prompted me to glue thin rubber (washer
like) grommets on the side wall of the rear-flared section and
since the grommets had a hole in the center, the sliding pin
coming out of the gull wing panel still could do its insertion
thing. I used Stick n' Seal gel which can be easily removed with
glue remover (Oops), if the need ever arises, and allowed 24
hours for it to really get a good hold.
