Old 03-13-2006, 07:29 PM   #35 (permalink)
ekological
ekological's Avatar
Images: 13
Originally Posted by II-soon
I connected the grounding wire back to where it was original plugged. Is that ok? Also the FM reception does get worse when the lights are on. I'm thinking about relocating the antennaes further away from the ballast to see if that solves the problem.
Connecting the grounding wire back doesn't matter other than keeping it from dangling. On the wire harness side of things, I purposely did not pass power or ground through since it would no longer be needed and there would then be no risk of shorting anything out. Hmm...I guess I'll know better when I upgrade my lights to the 50watt setup, but if you do relocate the wire to be a bit further away, please share your observations.
Custom Plug-N-Play Elise HIDs, Arqray SS Double Tip Exhaust, RAC Monolites
ekological is offline   Reply With Quote
