Old 03-19-2006, 01:36 PM   #96 (permalink)
sandsmuseum
Exige enthusiast...
sandsmuseum's Avatar
Images: 33
SVAG, shifter replacement, radiator
I took my Elise into SVAG (Silicon Valley Auto Group) to have the shifter replaced. I happened to mention I needed to add coolant a couple of times.
The shifter was replaced quickly and a pressure check of the cooling system showed a cracked radiator. It took the weekend to get the part and the car was returned to me, detailed and all six days after I dropped it off. Thanks to Andrew, Robert, Rich and the rest of the crew.
I remember when the we first started getting our cars, some of us were so amazed that the cars were arriving, we would go out to the garage at night and check to see if it was really there. I remember doing it. It was interesting to see my emotional reaction to go out there and see an empty spot in the garage. And I have had my car for a year and a half!
Contrary to you all, I do not notice any difference in shifting or strength of the lever. My original shifter was smooth and precise. The new one is the same. I did notice it was moved over slightly towards the passenger side but I will adjust that later. I do not like the new shift ball. I prefer adding Teflon tape to the threads and getting it tight and straight rather than setting the set screw. The edges of the gear numbers and the set screw hole are sharp and I can feel the metal edges catching on my skin. Looking for a replacement now...
www.sandsmuseum.com
antique coin op repair
mod for the Library on EliseTalk
sandsmuseum is offline   Reply With Quote
