Old 03-19-2006, 04:13 PM   #97 (permalink)
Stan
Originally Posted by sandsmuseum
I prefer adding Teflon tape to the threads and getting it tight and straight rather than setting the set screw. The edges of the gear numbers and the set screw hole are sharp and I can feel the metal edges catching on my skin. Looking for a replacement now...
You can still do the teflon deal and then epoxy the set screw hole shut. You cannot see the hole in any event.
On my new-style shift ball I did the following:
* Sanded the setscrew hole by hand to create a rounded edge. This helps a lot.
* Filled the engraved shift pattern markings. My son did that, it is easy. That helps a lot too as the edge is softened and the depth is reduced.
