Old 03-01-2006, 04:35 PM   #52 (permalink)
JayHass
Turbo Powered
JayHass's Avatar
Originally Posted by Stan
Yeah..and other stuff such as the reponse going into and coming out of the throttle. You can log the Elise TPS by tapping into the green wire with the yellow stripe at the throttle body. It's loggable at the 0-5volt inputs of your device.
Okay based on this, I went into the log files for the Greddy on a random 6psi run.
1st gear (Which has great lag time due to less load than other gears.)
7.76 seconds into it, 22% throttle, -1.7psi boost, 3945rpm
7.96 seconds into it, 75% throttle, .7psi boost, 4483rpm
8.16 seconds into it, 98% throttle, 3.1psi boost, 5025rpm
8.36 seconds into it, 99% throttle, 5.8psi boost, 5706rpm
2nd gear shift
10.28 seconds into it 11% throttle, -8.1psi boost, 6033rpm
10.78 seconds into it 96% throttle, 5.6 psi boost, 6117rpm.
Basically, looking at the graph it's taking me 1/2 second to depress the throttle fully as the TPS line from 10.28 seconds to 10.78 seconds goes up like / and then flattens at 100% from there and by the time the throttle is down, the boost is there. Step on the gas, by the time it's at the floor you have boost. That's the best way I can describe it.
Jay Hassinger: Häss ProTurbo
Built to a standard and not a price.
00 MRS Turbo - 11.2@119mph Stage-II+ Hass Kit
JayHass is offline
