Thread: Door sagging?
Old 04-06-2006, 03:12 PM   #9 (permalink)
Slag
Slag's Avatar
Originally Posted by paulhastings
My doors are not perfectly lined up side to side and never have been. They open and close well but, you can see one side is flush with the body and the other just lifted slightly. Not sure if this is a similar issue?
You can adjust the bolt that the door closes into to make it a better fit. Not sure how to describe it, but it is the big bolt that the door latch mechanism catches on to. My passenger door started to not shut properly & I noticed this bolt was loose & tightened it up. Then I noticed the driver side door wasn't as flush, so I adjusted that one.
2005 Elise Green/Tan, Arqray Double Tip and Arqray Sport Cat, ITG Intake
Slag is offline   Reply With Quote
