Old 09-11-2006, 11:34 AM   #48 (permalink)
Stephen
Waiting for next Lotus...
Stephen's Avatar
Originally Posted by bluejae
i almost didn't catch the "j/k" part...
but anyway...
"It is the black wire on the same end as the pink and green wire."
from the picture on post#1... it did say 13... so i'm hoping that there will be numbers like the one in the picture... then finding number 13 and hoping that it's black won't be difficult...
but going by just the description "...same end as the pink and green wire." i'm not sure where to look at...
from the left... i see what looks like 2 pink wires... and then 2 green ones in the middle... green/white and green/red?... and then another green on the far right... and then like 3 purples in the middle along with what looks like red/white... oh... and a bunch of black wires all over the place...
i'm sorry for asking so many questions before opening up my car... but i just want to make sure i've got everything down...
I couldn't even get to the pin connector, I just found the bundle of wires coming from it. You can tell the antenna wire because it is ouside of the bundle and is not taped up (or at least not taped up as much). Also, if you find this one and pull a little you should be able to free it and pull the end of it out (since it is an antenna). Then you can just connect to the end of it with a longer wire. Try that and let me know if it helps you find it.
Stephen
2009 Mini Cooper JCW - Dark Silver/Black - sport suspension/cold weather package
2008 997 GT3 - Carrara White/Black - PCCB's - 350 lbs of weight reduction
Past Lotus Cars: 2005 NFB Elise, 2007 CO Exige S, 2005 AR Elise, 2008 CO Exige S 240
Stephen is offline   Reply With Quote
