I think the Tripoint unit in a few weeks should be tested enough that they can do the job for half of your budget, or maybe 10k from the posts of the guys over at the monkey board. If lotus is using a sc and not changing the compression and internals, then it should be good enough for us, plus the sc directly address the weakness of the 2zz torque. Plus look at it this way you have a track tuned 240R for less than 80K. elise 45, tracks mods 5-8k, sc 10K
ruffly 65k, still 15k less than 240r, which you can not drive on the street if you wanted to. The ecu thing is the only conern!
