Old 09-25-2006, 05:35 AM   #72 (permalink)
Jim Itin
My worry is that the end of the wire is stripped like it was spliced into a crimp connector in the harness. Is the antenna wire stripped on the end or did I just yank apart some other important splice like a ground wire or something?
The foam over my alarm is wedged in super tight and will take a major dissection effort to remove so it's not easy to check the connector numbers to see if I got lucky. Anyone know if the antenna wire is pre-stripped?
Dennis,
I had the same panic attack, but at least on my car (early '05 model), the antenna wire was only about 6 inches long, and the end looked sorta
stripped (definitely not cleanly cut). I extended it about two feet, and got much better range. So it must not have caused any problems. Although I was able to pull the foam out (huge effort), I think that some have had some luck with just pushing it back into the cavity further.
Jim
'62 Alfa Sprint
'65 Alfa Spider Veloce (2)
'88 Alfa Milano 3.0L
'91 Ducati 900 S/S
'05 Elise (#0294),Magnetic Blue, Blk Touring, hardtop
Jim Itin is offline   Reply With Quote
