Mark,
Thanks for the info, however, my 2006 Elise Sport does not have the track pack set up. It has Ohlins with remote reservoirs in both the front and back to adjust compression damping. The rebound damping is adjusted with a collar similar to the track pack you described. So, I have two adjusters on each corner. There are no markings on any of them....just knobs to turn. The car was set up with all 8 adjustments fully counterclockwise (softest setting). I recently adjusted each knob one full turn clockwise and the result was much better handling (no wobble in hard turns on entrance ramps) with very little deterioration in ride quality. I could use some advice on the best way to set up my type of shocks....other wise it's going to be a lot of trial and error. Thanks in advance.
Lou
